1978 - 1996 Big Bronco
No power ... yeah, none
Old Mar 20, 2005 | 02:41 PM
anemptycokecan's Avatar
anemptycokecan
89 bronco seems to have quite a few problems.
The most annoying being that it has no power whatsoever.
With the truck in park I hit the accelerator and it takes a bit of time for it to climb in rpms. It doesnt really shudder or fight it, but it just creeps up in rpms so slowly. Almost like im just pressing the pedal slowly.
It also as no power during idle, If I put it in gear during Idle the truck usually dies, if it doesnt die turning the wheel while in gear certainly does the job.
I cleaned out the IAC and some other ends yesterday, didnt help much.
The only code it gives me is (33) Egr valve. SO I disconnected the rusty valve from the intake and plugged the hole, no change.
I notice there is oil in the air filter housing. When I thook the trhottle body off for cleaning there was oil behind it as well.
The guy who owned it before me did not take very good care of it.
any idea's ? 302 v8 EFI.
Old Mar 20, 2005 | 03:54 PM
anemptycokecan
Was outside earlier, adjusted the timing. Helped out a bit, not as much knocking.
Throttle reponds a bit better now.
Noticed a nice amount of smoke comming from pcv spout in filter box when reving while under a load(In drive, parking brake on).
The smoke had a gassey odor to it(not that kind ). Not to sure what to do next, was hoping the engine would be salvageable untill I could have it rebuilt, eh' maybe not. Thing smells like a friggin lawn mower.
Any idea's ?
Old Mar 20, 2005 | 04:04 PM
tex94F250's Avatar
tex94F250
Unhappy Smoke in the crankcase
A compression check is in order. Is there any evidence of water in the crankcase? Look under the oil filler cap and see if there is any whitish residue. Do a dry, then wet (a little oil in the cylinder) test. Cylinders should read similiarly. Post when done. It sure sounds like a compression issue.
On a curious note, have you checked the fuel pressure at the rail schraeder valve? Have you changed the fuel filter lately. (Bleed system prior to changing!)
Old Mar 20, 2005 | 04:13 PM
anemptycokecan
Fuel filter is supoosedly new.
no residue, just a dry brown film.
I'll have to go get a compression check gauge monday.
If the compression is bad whats next ?
Old Mar 20, 2005 | 04:31 PM
tex94F250's Avatar
tex94F250
Rebuild, sorry.
Old Mar 20, 2005 | 04:47 PM
anemptycokecan
ah poopies, guess i'll call around and check prices.
Thanks for the help.
Old Apr 15, 2005 | 11:17 AM
WhiteBlazze's Avatar
WhiteBlazze
So how did the compression check go?
What is the compression supposed to be in a 96 302 stock engine?
Old Jun 24, 2005 | 07:29 AM
Band-aid Kid's Avatar
Band-aid Kid
Could a clogged Cat Converter do this as well?
Old Jun 24, 2005 | 01:04 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Band-aid-Kid, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 24, 2005 | 03:18 PM
oldbluebronco's Avatar
oldbluebronco
Same proble when I bought mine. Bad cylinder. Had it rebuilt runs great if those darn 35's weren't holding it back. Same symptoms as you though. Oil in airbox, smoke if blow bye disconnected, stuck erg, bad compression in # 8 . never died, just ran kinda *&%$. Hope everything works out. I had mine rebuilt for 1900, including new motor mounts and have to buy a new core.
Old Jun 24, 2005 | 03:39 PM
Kemicalburns's Avatar
Kemicalburns
should have done a 5.8 swap for about 900 less
Old Jun 25, 2005 | 09:14 AM
Streetgang's Avatar
Streetgang
The problem w/the #8 cyl is a very well known issue on some year range Broncos. I think Ford rearranged the intake vacuum lines or something to that effect, and had it resolved by the 93MY.
As far as the original posters questions......first thing would be a compression check. I would also find out when the last tune up was done.....check the PCV valve.......check to see if the cat(s) are clogged.....
when you set the timming.....you did remove the SPOUT right? I have my truck at the factory 10*BTDC....and I was thinking about going to 12* or 13* and see how she does.....but thats when I get to it.
Old Jun 25, 2005 | 11:22 AM
Kemicalburns
these motors like at leat 12*btdc with spout removed for sure. anything above that you really have to move up in small amounts otherwise it will ping. 12 is a safe but noticable improvement
