pcv valve
Old Mar 19, 2005 | 06:44 PM
tony b.'s Avatar
tony b.
Question pcv valve
Well did my 1st tune up on my 98 explorer spt.oil,filter,belt,plugs,pl. wires,fuel filter,The only thing I couldn't change was the pcv valve, My question is where the hek is it to begin with looked all around wasn't able to locate it!
Old Mar 19, 2005 | 07:46 PM
K2JJB's Avatar
K2JJB
what engine does you X have?
Old Mar 20, 2005 | 07:55 AM
tony b.'s Avatar
tony b.
it's the 4.0 sohc
Old Mar 20, 2005 | 09:28 AM
98xlt's Avatar
98xlt
its near the rear top of the engine by the firewall. access it from the passenger side. the bottom of the pcv sits in rubber tubing and the top of the pcv splits off to two smaller tubes leading to the valve covers. sometimes it helps if you remove that black shroud that says "4.0", but its not absolutely necessary.
Old Mar 20, 2005 | 10:03 AM
tony b.'s Avatar
tony b.
You know I had that one in my hand yesterday but wasn't sure because it had a y split at top,& it was held in place by a plastic clamp. I started to pull on it but wasn't sure because the on the auto parts sold me didn't have the y split, it had like an f split one was small & one little larger , the auto part guy told it had a blocker because they sometimes use both & some don't!
Old Mar 21, 2005 | 11:53 AM
Justmill3's Avatar
Justmill3
I pulled mine and broke the clip. I got the T conector off, but could not get the PVC out of the hose. Well I quite. If I could get it out of the hose, how do you get the new one in???? There is no room to work back there
mvvette97
Jan 10, 2015 11:18 PM
08F1Tizzy
2004 - 2008 F150
Nov 15, 2012 08:41 AM
94Rangerbeater
1983 - 2012 Ranger & B-Series
Oct 25, 2005 04:51 PM
redwood
Jul 9, 2004 03:15 PM
blima
Oct 13, 2002 10:50 AM
