Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Which Torque Wrench Is Best Buy?
Old Mar 25, 2005 | 08:59 AM
Silver Streak's Avatar
Silver Streak
Originally Posted by Hangfire
I'd say go with the Snap On if you have to do it right!
Ditto! The Snap On torque wrenches are not that much more expensive than some of the others on the market. I bought three of them last year and got a discount for getting all three. I've got a middle of the road Craftsman that I use at home, but at work Snap On gets the nod. Most of my tools are Craftsman, but when precision counts I'll buy better tools.
Don't forget a torque angle meter. Most new cars are going to this method. The meter is only about $15, but is valuable when the spec is 20 ft-lbs + 34 degrees. After you do the initial torque, mark a line across all the bolts in the same direction so you will know which ones are already done if you have to take a break from the job for a few minutes.
Old Mar 25, 2005 | 09:27 AM
CheapRanger's Avatar
CheapRanger
We all had our torque wrenchs calibrated at the shop a couple of years ago (get offered the service by a client once a year) one of the other mechanics sent his harbor freight. Mine are Craftsman, Proto, and Hazet as well as a no name one I bought when I was 16 at Wards. Between all five torque wrenchs the one that was off by more than one percent was the proto that UPS had delivered. Craftsman warranty on Torque wrenchs are the same as Snap~on's, Harbor Freights etc. None of them cover calibration, although they offer the service to calibrate them, but judging by the torque wrench that UPS brought you need to get it calibrated locally so it doesn't get thrown out in shipping.
Craftsman's liftime replacement warranty does cover the old beam style.
Old Mar 27, 2005 | 12:21 PM
bigredsbronco's Avatar
bigredsbronco
I have both craftsman and snapon and have had one of them for 22 years a year ago they were recalibrated and they said that all of them were still ok, the oldest one is a snapon and the next is a craftsman. my snap on dealer has been a mac rep, and a matco rep and he likes the snap on best because in the shops snap on sells best and as he says " its a man show thing" SNAP ON UGH! UGH! UGH! get em tim
Old Mar 27, 2005 | 06:31 PM
Ruckus's Avatar
Ruckus
Smile
That Snap On sounds Snappy .Thank You very much for sharing your experience with Torque Wrenches.Now I need to shop for the best price?Thanks Again!
Old Mar 27, 2005 | 07:23 PM
sportscar's Avatar
sportscar
I am a fan of most Craftsman products. But I will not buy another Craftsman torque wrench. I find the dialed in setting will not stay put. (Torque wrenches do not carry the lifetime warranty).
I just bought a SK 3/8 10-100 ft-lb unit. Very nice positive vernier lock, but the engraved numbers are hard to see in low light. We used Utica wrenches at GE Aerospace. Now, those where some nice pieces. They came with a calibration card and were traceable back to the National Standards Bureau. I priced the out...$300…you get what you pay for.
Old Mar 27, 2005 | 07:49 PM
cetane anyone ??'s Avatar
cetane anyone ??
I have heard that it is important to back off to "0" setting on clicker type t. wrenches when they are not in use----such as the end of the day, etc. This is to prolong the accuracy,etc. Has anyone else heard this?
Old Mar 27, 2005 | 11:22 PM
bigredsbronco
yes, if you read the little instruction sheet that comes with most of them it tells you that you must return it to the lowest setting ( may not be zero) after use.
Old Mar 29, 2005 | 02:35 PM
GeneStoner's Avatar
GeneStoner
What's the word on digital T-wrenches?
Old Mar 29, 2005 | 03:29 PM
kgwld1's Avatar
kgwld1
My snap on's came with a certificate of calibration. This a example of my 1/4 inlbs. clicker type
Ex.-
Tolerrance +or-4%
Clockwise Readings
40.00 40.76 1.9%
120.00 119.61 -0.3%
200.00 200.57 .03%
Counterclockwise
40.00 39.62 -1.0%
120.00 118.57 -1.2%
200.00 200.28 0.1%
When we went thru our ISO inspection my crafstman where out as much as 12% I use them as breaker bars now.
Old Mar 29, 2005 | 04:15 PM
Franken-Truck's Avatar
Franken-Truck
Read the instructions
