Sponsored by: Auxito
How do to drain torque convertor
Old Mar 18, 2005 | 05:55 PM
Racer X's Avatar
Racer X
I'm about ready to put in a shift kit in my 98 NASCAR F150. How do you get the old fluid out of the convertor. I should use Mercon 5, right.
Old Mar 18, 2005 | 06:08 PM
peppermrj's Avatar
peppermrj
There actually is a drain plug. You take out the rubber plug in the bell housing and look for the drain plug while rotating the torque converter. I just used a screw driver on the flywheel gear.
Old Mar 18, 2005 | 06:50 PM
Ted98's Avatar
Ted98
I put an 18mm socket on the crank shaft bolt and rotated the engine.
Old Mar 19, 2005 | 08:27 AM
MrBSS's Avatar
MrBSS
Not all trans have the torque converter drain plug. Check your dip stick to tell which Mercon you should use.
