U-Joints
Old Mar 18, 2005 | 01:27 PM
SLM-F250's Avatar
SLM-F250
U-Joints
U-Joints with or with out grease fitting when replacing.
Old Mar 18, 2005 | 11:43 PM
KcinMI's Avatar
KcinMI
Thats like asking do you want fries with that!! In my PERSONAL opinion, the whole idea that; "If we make everything greasless so no one can put the wrong grease in it" is crap. Now I know certain greases are for certain things, but even the wrong grease is better than no grease. So go with the zerks.
Old Mar 19, 2005 | 07:10 AM
c_rossman's Avatar
c_rossman
Most times you wont be able to grease the ujoints on the truck anyways. I have greaseble ones on my front driveshaft which I can lube, But cant lube the ones on the rear without pulling the driveshaft off.
Old Mar 19, 2005 | 07:26 AM
KcinMI's Avatar
KcinMI
possibly because you have straight zerks and not ones with either a 45 or 90 degree angle. Ive never had to remove a driveshaft just to grease the joints. Not to mention greasing a U-joint while its not bolted in will push the cups off if its a flange type joint.
Old Mar 19, 2005 | 09:03 AM
c_rossman's Avatar
c_rossman
Yeah they are straight, what the Ujoints came with.I just take the drive shaft off, like 2 minutes, Put the ends in the vise and grease them up. Nice time to grease the slip yoke anyways.
