Sponsored by: Real Truck
Another wire location thread...
Old Mar 18, 2005 | 08:48 AM
CyberJay's Avatar
CyberJay
I need a wire around the fuse box that is RUN ONLY. This is for my battery isolator. Should be hot only when the truck is in run. Just tripping a solonoid, doesn't need a lot of power.
2nd, What color are the front speaker wires on the connector behind the headunit?
Thanks!
-Jay
Old Mar 18, 2005 | 10:14 AM
a12play12's Avatar
a12play12
Here ya go, hope this helps,
Good Luck R.
Old Mar 18, 2005 | 10:21 AM
CmprSpecial's Avatar
CmprSpecial
Location is dependant on year, but there is a white wire with a light blue trace that (on the '04) is behind the radio in a harness labeled "customer access wires". It is hot only when the engine is running. It's there to run the PTO if installed.
Old Mar 18, 2005 | 10:49 AM
CyberJay's Avatar
CyberJay
Awesome.. very helpful. Thank you.
-Jay
