Sponsored by: Auxito
steering box
Old Mar 18, 2005 | 07:54 AM
Dave Hughes's Avatar
Dave Hughes
steering box
Proceedures on seal kit installation?
Old Mar 18, 2005 | 06:20 PM
Racerguy's Avatar
Racerguy
Hi Dave and welcome to the forum
Which seals are you replacing?
You'll need to remove the steering box and the pitman arm if you're doing the lower seals. To remove the pitman arm you need a puller.
Old Mar 19, 2005 | 08:15 PM
Dave Hughes
Steering box seals
Thanks for your support. Things went well.I.ve got a tip for upper seal removeal if any one is interested?
Old Mar 19, 2005 | 08:35 PM
Racerguy's Avatar
Racerguy
Sure.
Someone here will probably benefit from the tips some time or another.
Did you replace all the seals in the box?
