Sponsored by: Kumho
Suspension questions?
Old Mar 18, 2005 | 12:41 AM
hotrodkid05's Avatar
hotrodkid05
I have an 81 ford f150 stepside and i was wanting to lower the front of it, maybe the back too, but i dont want to slam it to the ground, all i want is to bring it down a few inches and give it a slight rake for a nice stance and slightly better gas milage.
Aaron
Oklahoma
Old Mar 18, 2005 | 02:20 AM
Snow-man's Avatar
Snow-man
drop
i'm going the same using 3inch drop I-beams and 5inch axle flip in my '81 F100
Old Mar 18, 2005 | 12:38 PM
hotrodkid05
where are you getting your drop kit from. I found a set of drop beams that you are talking about but they are $600. That is more than i want to spend on it at the moment. If they were $200 or something like that i might think about it more.
Old Mar 18, 2005 | 04:11 PM
Snow-man's Avatar
Snow-man
drop
thats the kind of price range, or you go dream beams 3 times that price or maybe get lucky on ebay... another alternative is to use just drop springs, up to 2 inch drop is ok before you start having any other dramas with alignments...
Old Mar 19, 2005 | 08:32 PM
hotrodkid05
have you found drop springs. if so let me know where and or how much a set are please.
Old Mar 20, 2005 | 01:37 AM
Snow-man's Avatar
Snow-man
drop
LMC do drop spring kits, 2inch front and back or 2 front and four back
Old Mar 21, 2005 | 07:57 PM
mustange70's Avatar
mustange70
Take a look at my flareside in my gallery hotrodkid, if you like what you see i can give you an in depth details of what i had to do.
Old Mar 22, 2005 | 04:55 AM
Snow-man's Avatar
Snow-man
tyres
hey mustang what size tyres you running, i'm rolling on 15x8's and looking at a drop but tyres are to large... by the way looks nice...
Old Mar 22, 2005 | 03:49 PM
mustange70's Avatar
mustange70
235/60R15's on the front and 275/60R15's on the rear (about 1-2" shorter than a 235/75, but way wider, looks a lot better in person as that width fits the fender perfect), and the rim size is 15x8. In that picture the amount of drop is approximately 3/4, as i used a flat spacers under the spring along with a 2" drop spring, but the spring was sitting on the stablizler mount, so what when i stiwched to a set of i-beams with the camber/caster adjustment i put the proper spacer back in the front and the front tires are to short, when i get new tires for it this summer once the snow is gone i will probably go with a 235/65 up front.
