Cold natured skip!!
Old Mar 17, 2005 | 08:21 PM
PICCALO358's Avatar
PICCALO358
Cold natured skip!!
Got a 1980 f100 inline 6-300,idles great during normal weather, when it gets cold and damp it idles very rough and wants to cut off. Thanks for any suggestions.
Old Mar 18, 2005 | 08:00 PM
phatpony's Avatar
phatpony
I have an 81 F-100 with the inline 6 that had the same kind of problem. What I found was that the choke did not close, thereby not allowing the fast idle cam to drop. I pulled the choke housing off and doused it real good inside the housing with carb cleaner. That got the choke to working, but the linkage still had a little bind because it hadn't moved in umpteen years. I sprayed it down real good with some liquid wrench, and now I have no problems with fast idle, she starts right up and runs like a top.
If that dont do it for ya, replace the dist cap and rotor. You may have some moisture building up in there.
Hope this helps. Good luck.
Old Mar 20, 2005 | 06:25 PM
PICCALO358's Avatar
PICCALO358
I was leaning towards a choke problem, the choke seems to work when it feels like it, and I will check that out.
