dash and reverse lights
Old Mar 17, 2005 | 12:58 PM
ltj427's Avatar
ltj427
I have a 76 f-150 ranger. The reverse lights and the gauge lights donn't work all the gauges work. I've allready switch over all the fuses even replaced the reverse bulbs. Anything else I should try. I work the late shift so its dark going home and I am not to crazy about speeding tickets thanks
Old Mar 17, 2005 | 01:28 PM
mrsuperman15's Avatar
mrsuperman15
there are bulbs inside(behind) the panel that could be out, but it would be odd if they are all out, this may sound dumb but have you tried turning the head light switch, the lights should get brighter as you turn the switch to the left (counter-clockwise) and all the way to the left should turn on your dome light, sorry if you've already tried that
Old Mar 17, 2005 | 01:32 PM
73Custom's Avatar
73Custom
Do the lights work on the heater control and over the wiper switch? If so, then you have a problem in the guage cluster, most likely a poor connection or burned bulbs.
Is this a auto or manual trans? Auto trans has the switch at the base of the column - reverse lights are run by the neutral safety switch... 3spd manual trans has switch in linkages at base of column on engine side of firewall. 4spd manual trans has screw-in switch in the top of the trans. Find your switch and test for power to the switch and on other side when in reverse. Let us know what you find.
Marty
Old Mar 17, 2005 | 05:21 PM
ltj427's Avatar
ltj427
its an auto and the lights do work over the wiper and heater control and on the column for the gear. Is it difficult to check the connections keep in mind I have no experince working on cars
Old Mar 18, 2005 | 07:22 AM
pacochico's Avatar
pacochico
check the lamimated map **** on the back of the gauge panel some times the bolts that hold the gauges are loose and they are not making contact thats how the panel get electrical current with tha map **** look into. if the map **** is damage that another reazon the cluster is not working so you may have to chanched
Old Mar 21, 2005 | 12:36 PM
73Custom's Avatar
73Custom
The fact that the other dash lights work, tells you the light switch and wiring in the dash is working. So the problem is in the guage cluster.
Checking the guage cluster is pretty easy. Just need to remove the plastic trim around the guage cluster, then remove the cluster. On the back, there are two twist in bulb holders that light up the dash lights, check that these bulbs are good. Also check that the contacts on the printed circuit are clean and tight. Clean the contacts and install new bulbs, then check to see if it works.
Let us know how it goes...
Marty
