Lincoln help
Old Nov 18, 2001 | 04:04 PM
joeyv821's Avatar
joeyv821
Lincoln help
Hi, sorry i know this is a ford site, but lincoln is made by ford, and i own 4 fords , well to the problem:
I have a 1989 Lincoln Continental and just put a new battery and a new alternator in it, and the thing will never start up unless i charge it, then the battery gauge flashes saying that my battery has to much power in it, after i charge the battery and start it then turn it off, i can start it back up for like 2 minutes then it will be dead again...
Any help will be greatly appreciated.
Thanks.
Old Nov 18, 2001 | 05:15 PM
Greywolf's Avatar
Greywolf
Lincoln help
Sounds like a short.
You should put a meter on it between the neg terminal, and the lead for it (disconnect the lead from the post).
If you see a large voltage drain, start pulling fuses to isolate what circuit is causing the drain.
At that point, follow the wiring diagram.
I have seen cigarette lighters and in-dash clocks (old style) do this before...
Old Nov 18, 2001 | 07:18 PM
jagabom's Avatar
jagabom
Lincoln help
carlos velez
New Member Introductions
Dec 2, 2007 10:23 AM
78bigunns
Sep 18, 2006 09:40 AM
TallPaul
Nov 15, 2001 11:59 AM
