General Automotive Discussion
86 cutlass dashboard noise
Old Mar 17, 2005 | 11:15 AM
dblommel's Avatar
dblommel
i have an 86 cutlass and there is an anooying rattling noise coming from my dash. it started out just when I accelerated but now its happening all the time. I am hoping its just the speedo cable. but i have the whole instrument panel apart and im thinking it could be in the part at the end of the cable. (The peice that the needle and odometer are on between the needle an the actual speedo cable). any help would be great. thanks david
Old Mar 17, 2005 | 11:24 AM
JoeBlow's Avatar
JoeBlow
Try some graphite lube on the end of the cable.
Old Mar 17, 2005 | 11:34 AM
dblommel's Avatar
dblommel
do you think that will do it for sure?
Old Mar 17, 2005 | 12:20 PM
Boss_358's Avatar
Boss_358
Moved from Transmission forum.
Old Mar 18, 2005 | 05:33 AM
old fool's Avatar
old fool
When I worked in a Ford dealership we would get this complaint from time to time. A little lube on the hood bumpers usually cured it. The sound would travel into the dash and make you crazy trying to find it. Bug shields on pickups would also make weird noises around the windshield.
Old Mar 18, 2005 | 02:48 PM
Arrow201's Avatar
Arrow201
I have an 83 Buick Regal, I once had an annoying noice coming from the speedo cable. It was especially noisey when it was cold. I lubed it, worked fine afterwords. Like, JoeBlow says, just put some graphite lube on it and it will quiet down.
