Emissions test problem
Old Mar 17, 2005 | 12:38 AM
ExpyJeepin's Avatar
ExpyJeepin
I posted this in the Expy forum, and it was suggested that I post here.
2001 Eddie Bauer Expy 4x4 5.4l 75,000 miles.
I have failed two emissions tests now with this vehicle. It failed when the emissions center hooks up to the ODBII computer, because the I/M readiness codes are set to "Not Ready" for all the emissions equipment. (Cat, EGR, O2, etc) It passes perfectly fine when run on the treadmill, and all parameters are within the required ranges.
I have no codes in the computer, and no MIL on. The truck runs great, and we have never had a major problem with it. I just changed the oil and PCV valve, and cleaned the throttle-body. The emissions tests were two years apart, both times with the same failure. The dealer looked at the truck after the first time, couldn't find any codes, and reflashed the computer to be on the safe side.
So, any input? Do I have a flaky computer? One person on the Expy forum suggested that maybe the ECM was resetting itself periodically. Anyone else had an issue like this?
Thanks for any help you can provide.
--Mike
Old Mar 21, 2005 | 10:27 PM
ExpyJeepin's Avatar
ExpyJeepin
I am still monitoring this truck, and other than the "Not Ready" value on the I/M readiness checks, it checks out clean.
Does anyone know how many driving cycles are required before the I/M checks are supposed to complete? I am going to yank the battery cable off to reset the ECM, and monitor it for another week to see if they complete.
Any help would be greatly appreciated.
Thanks,
--Mike
Old Mar 21, 2005 | 10:54 PM
LxMan1's Avatar
LxMan1
I would think that within a week, it should be set. You must drive in all kinds of conditions such as WOT, cruise at 65, and that kinds thing.
Old Mar 22, 2005 | 06:44 PM
furrby's Avatar
furrby
i don't know about your truck but on my 01 f150 it has a drive cycle of about 20 miles. i had the problem with the egr sensor going bad. got it fix at the dealer and they said after about 20 miles i could get it inspected. hope that helps.
furrby
ps. after about 25 miles i was able to get it inspected.
