Sponsored by: Real Truck
Sliding Bed Covers?
Old Mar 16, 2005 | 10:10 PM
BeetleJuiced's Avatar
BeetleJuiced
Sliding Bed Covers?
Has anyone had any experience with sliding, rollback type bed covers? Good or bad? Which brands or models should I consider or stay away from? I have a new F350 CC Dually longbed. It will be mostly used for recreation use, dirt bikes, quads, towing the boat, etc. Possible near future 5th wheel toy hauler trailer.
Thanks
Old Mar 17, 2005 | 01:42 AM
LaredoF350's Avatar
LaredoF350
I will be watching this one. I like the RETRAX for its build quality but I think the JACK RABBIT looks a bit better, but I still haven't decided between the two.
Old Mar 17, 2005 | 07:14 AM
04FordHarleyF250's Avatar
04FordHarleyF250
I use the Retrax cover but I have a short bed. On the short bed the cover lays flat all the way from front to back. The Retrax cover is great because there is no retracting hardware to fail like in older designs. Check out their web site for all the details.
04FordHarleyF250
Old Mar 17, 2005 | 07:38 AM
vette69's Avatar
vette69
I've read on here before that the retractable covers tend to leak. No personal experience, just what I have read.
Old Mar 17, 2005 | 07:49 AM
Frobozz's Avatar
Frobozz
I like my Truxedo cover. It rolls up but takes up no room at the front of the bed when it's open, unlike the hard rolling covers. It uses velcro down the sides not snaps so it's easy to open and close. It is just vinyl so if you're really worried about securing the bed contents in a high crime area it's no good. It's fairly weatherproof though at certain parking angles it can let a little water dribble in the front corners in a hard rain. It only started doing that after I put it back on after getting a spray in bed liner, so I probably just didn't get one of the seal flaps positioned properly up there.
Duncan
Old Mar 17, 2005 | 08:36 AM
Red Boat's Avatar
Red Boat
I have the jackrabbit on my truck and IMO it's the best thing since sliced bread......lol. BUT you must treat that vinyl cover every month or so with STP "son-of-a-gun" or a protectant that is sold by the manufacturer (pace products, and that can get expensive) if you do not the vinyl WILL fade and it will then be light grey vinyl and there is no way to get it black again. You can treat it and it will turn black again but once the "son of a gun" dries it will turn back to grey again. I tell you this from experience!! If you use other protectants (no personal experience but I have been told thats what will happen) on the vinyl it will cause the vinly to get hard and crack. Overall I am very happy with mine just not the vinyl covering.
Old Mar 17, 2005 | 09:20 AM
sgthawkusmc's Avatar
sgthawkusmc
I installed a rollback then removed it immediately. They take up way too much room in the front of the truck and down the side rails. I guess it depends on what you'll be putting in the bed. I have a short bed already, I don't need it any shorter... I put in a hinged snap tonneau cover and I love it. I probably wouldn't get a hinged one again though. Just the snaps would be fine for me.
Old Mar 17, 2005 | 09:35 AM
04FordHarleyF250
The design of the "jack rabbit" is fine at first but over time will not hold up. The spring retract will fail through use and weather. That vinyl covering will weather, crack, and seperate over time and use. The aluminum panels slide directly on the rails and over time will wear and no longer slide smoothly.
Retrax has looked at each of these issues and solved them. This cover rides on roller bearings for a consistent smooth operation with no retract spring to fail. Retrax also allows the cover to be locked in any position (Jack Rabbit is every 12 inches) and it can handle some weight should something (or someone) sit on it.
Both offer a clamp on design so if you need to remove it from the truck, it can be done easily without leaving damage.
I would suggest getting a "seal kit" for the tail gate. Have you ever noticed that there is a gap around the tail gate on the superduty when it's closed? As you go down the road with a cover on the bed a vacuum is created and will suck dirt through the gap. A seal kit placed around the tail gate keeps this from happening.
A retractable cover is handy. Should you need to haul something tall you can open it up. Both companies offer a lock with their covers and since the tail gate has a lock, you can place something back there without the fear of it running off.
04FordHarleyF250
Old Mar 17, 2005 | 03:37 PM
LaredoF350's Avatar
LaredoF350
What do you think of the shiny finish on the Retrax and does it show swirls? The Retrax sticks up a bit on the side rails doesn't it?
Old Mar 17, 2005 | 04:03 PM
04FordHarleyF250
I have a black Harley Truck and the Retrax looks like the factory installed it. I removed the gaudy Retrax stickers on the rails for the smooth look. Yes, the Retrax sits above the rails as it overlaps the tail gate when it's up so water/debris doesn't run in. Check out the retrax website and play the little demonstration video to see how it operates.
04FordHarleyF250
Old Mar 17, 2005 | 04:06 PM
skilawyer's Avatar
skilawyer
i have the pace edwards. had it 6 months or so. vinyl is holding up, but it doesn't seem to retract like it used to. after owning this type, i think the roll-n-lock would have been a better choice for me. it seems to have better spring tension.
i really like the explorer series rails on my cover though. makes it nice to add my homemade headache rack, bike rack, tie downs etc...
Old Mar 18, 2005 | 03:42 PM
jorzac's Avatar
jorzac
What kind of fuel mileage increases did you see using a bed cover?
Old Mar 18, 2005 | 04:01 PM
skilawyer's Avatar
skilawyer
not sure of any mileage increase, if any.
i like to push the loud pedal too much.
Old Mar 18, 2005 | 07:34 PM
nhebert's Avatar
nhebert
I have the RollnLock bed cover. It does take up space at the cab, the gaskets do come out if you close it while the tailgate is down, but I remember the installer said not to do that. Im happy with it. Generally water tight except right at the gate. Better than a tonneau cover for me since I can retract it at the store and haul whatever I want to. You cant have a toolbox , ie the butterfly type, but its nice to go to the beach with everything battened down.h
slinginsaws
Sep 22, 2014 09:42 AM
LeoJr
Aug 12, 2014 05:11 PM
Texas Pete
2004 - 2008 F150
May 18, 2007 02:37 PM
Sudsrat
1997 - 2003 F150
Sep 4, 2005 09:19 AM
Sycostang67
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
May 5, 2003 11:06 PM
