302 bored .30 over?
Old Mar 16, 2005 | 08:36 PM
F-150Guy's Avatar
F-150Guy
302 bored .30 over?
i just started takin my engine apart to rebuild, and on all the pistons is stamped .30...what would this make my 302 in cubic inches now?
Old Mar 16, 2005 | 09:26 PM
Hawkeye77's Avatar
Hawkeye77
306.1344 CID
Hawkeye77
Old Mar 17, 2005 | 09:57 AM
Kemicalburns's Avatar
Kemicalburns
if that motor is already at .30 . i wouldnt go past .40. anything more and the cylinder walls will be real thin which causes overheating. some have gone .60 but the motor life is short lived. why are you rebuilding the motor?
Old Mar 17, 2005 | 10:03 AM
F-150Guy's Avatar
F-150Guy
i only have a compression of 2 on #7 cylinder, getting excessiv blowby with tons of oil going into the air filter. plus rear main seal is leaking, and so is the timing cover. I shouldnt have to bore it out...there isnt to much of a lip on the cylinders, should be abloe to get away with honing them.
Old Mar 17, 2005 | 01:00 PM
jrocco's Avatar
jrocco
Do yourself a favor. After you get the block completely disassembled, take it to a engine machine shop and have them check it.
If the block is OK have them hot tank it, hone it, and install the cam bearings.
The cost for this won't be much and you won't be taking a chance that all of your parts and labor will be waisted if the cylinders are out of round or too far gone to hone.
Old Mar 17, 2005 | 09:19 PM
TRaGiK's Avatar
TRaGiK
What year is the block? If it's pre 1980, a 60 over will NOT cause overheating. Prior to 1980, ford casted the blocks with very thick walls. I did a .060 on my 79 302, will absolutely NO bad effects. The only time it would ever overheat, is if it sat parked in the summer heat idleing for more than 20 minutes AFTER it had already warmed up. I beat on this engine every chance I got. Constantly turning 3200 rpms @ 60 mph (geared LOW), and probably 300 - 500 drag strip passes with around 15 - 20k miles on the street. When I sold it, it ran perfectly. No overheating, no ticking, no using oil.
However, if it is a 1980 or later block, don't go more than .040 over.
Old Mar 21, 2005 | 03:36 PM
F-150Guy's Avatar
F-150Guy
its an 80 f-100...i think the block is a 79
8086ford
Feb 29, 2016 10:39 AM
anthonym92
Oct 25, 2015 12:58 AM
almonyspm1
Aug 13, 2011 03:11 PM
Knouff Hick
Apr 21, 2004 05:11 PM
John with beastly 302
Oil & Lubrication
Apr 23, 2003 02:27 PM
