Bronco II Ford Bronco II
increasing oil flow
Old Mar 15, 2005 | 06:00 PM
websram42's Avatar
websram42
increasing oil flow
Hello all, I have an 88 b2 with a 2.9. I was wondering about opening up the oil passages o the valve train and possibly the crank. Has anyone done this and do you have the spec or process on how to do it? Thanks in advance.
Old Mar 15, 2005 | 07:41 PM
Ken00's Avatar
Ken00
You can do the free floating lifter mod, it helps with noisy lifters, gets more oil to the top end and frees up HP. I think this is cover in Sven Pruett's book, How to build and modify ford v-6 engines. Never heard of a mod on the crankshaft, I would worry about losing upper oil pressure.
Old Mar 20, 2005 | 11:11 PM
Stonegate's Avatar
Stonegate
I went with a high flow regulated pump. Works great. Builds to about 60 psi and drops to 45 at operating temp. Try not to unrestrict flow too much or you won't get enough pressure at the top of the motor.
