Oil & Lubrication
Transfer oil
Old Mar 15, 2005 | 05:16 PM
flhr's Avatar
flhr
Transfer oil
What is the best oil to use for the front and back cases in a 2002 Super Crew 4X4
Old Mar 16, 2005 | 06:36 AM
MBDiagMan's Avatar
MBDiagMan
What do you mean when you say front and rear cases? Do you mean the front and rear axles? If so, the front takes 75W90 GL5 and the rear takes 75W140 synthetic. If the rear is a limited slip it needs 4 ounces of limited slip additive when changing.
If you are talking about the transfer case behind the transmission it takes ATF.
Good luck,
Doc
Old Mar 29, 2005 | 03:13 PM
arrowpilot's Avatar
arrowpilot
Would you use the same for a 97 F350, 4x4, PSD?
What about fluid for the tranny (5spd man) and xfer case?
How do you tell if it is limited slip?
Sorry for sounding stupid!
Old Mar 30, 2005 | 03:43 PM
monsterbaby's Avatar
monsterbaby
Well a general rule of thumb on tcase, and tranny fluids is if it is an Iron case it uses gear lube, if the case is alum then use ATF. very general rule but it works most of the time I have found.
Old Apr 4, 2005 | 02:56 PM
jimandmandy's Avatar
jimandmandy
arrowpilot,
Yes, the tcase and trans take ATF. Good observation, monsterbaby.
If the axle code on the door post sticker has a letter like "H" in it, then it is limited slip.
Off topic: Do you own a Piper Arrow?
Jim
Old Apr 4, 2005 | 03:00 PM
arrowpilot's Avatar
arrowpilot
Thanks for the info.
No. I dont own or even fly a plane. I did used to be in the 82nd Airborne, though!
That is my name on www.TexasBowhunter.com.
Im just a redneck bowhunter from Texas.
Sorry if it seemed misleading.
Old Apr 5, 2005 | 10:45 AM
jimandmandy
I just took it in the wrong context.
Jim
