help needed with bearing clearence
Old Mar 15, 2005 | 03:22 PM
killbabies's Avatar
killbabies
i was wonderin if anyone could tell me what clearence i should be lookin for when i plastigauge my conrods and main caps on my crank, my motor is a 85 351w ho, i cant seem to find the spec numbers in my manual, so any help would be much appreciated
Old Mar 15, 2005 | 05:48 PM
F150'89's Avatar
F150'89
This is from a Haynes manual #36058
Rod bearing oil clearance:
Standard= 0.0008 to 0.0015 inch
Allowable= 0.0008 to 0.0025
Main bearing oil clearance:
Allowable= 0.0008 to 0.0026
Old Mar 17, 2005 | 12:30 PM
smoke n tires's Avatar
smoke n tires
those specs are correct but i personally think hard to get a used motor that tight without extensive machine work. i would say its fine with .002-.004". run 10-40 oil and drive it.
