Vaccum Leak
Old May 25, 2001 | 01:59 PM
Zemus_420's Avatar
Zemus_420
Vaccum Leak
Ok, I have a 85 ford f-150 with a 302, my truck has been stalling alot lately. Ive checked the air bypass valve cleaned it but truck still stalls out. But this time I smelled a nasty stinch coming from the tail pipe when it stalled out and thought it might be a vaccum leak. My question is; where do I start at, where are the vaccum hoses located and what do I need to solve this problem.
Oh!! and if any of you have a different opinion of what might be causing me to stall out please let me know.
Thanks Zemus420
Old May 25, 2001 | 03:38 PM
bjoern's Avatar
bjoern
Vaccum Leak
I'm not sure if a vacuum leak alone would make your truck stall, but my vacuum leaks cam from the colored plastic hoses: they had turned brittle and had broken several times. I replaced all of them with rubber hoses.
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N filter, MSD 6a ignition, Accel 300 8.8mm race wires, Accel supercoil, Accel rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: Dual exhaust.
http://brembs.net/cars/FordPU.html
Old May 25, 2001 | 04:53 PM
SteveH4954's Avatar
SteveH4954
Vaccum Leak
One of the best ways I have used to find a vac leak is to take solvent in an oil squirt can and spray the solvent around the intake an other possible vac leak points. If you do have a leak the engine will speed up when the leak is sprayed.
Old May 26, 2001 | 01:14 PM
jakegypsum's Avatar
jakegypsum
Vaccum Leak
