Sponsored by: Real Truck
6 inch lift
Old Mar 14, 2005 | 03:00 PM
nateduece's Avatar
nateduece
6 inch lift
i have researched anout every lift out there. right now i am aiming torwards a 6inch BDS lift. has anyone heard good/ or bad things about bds? or other lift companies? i also plow in the winter and will be running 37's in the summer so if anyone recommends somthing else i would like to hear some feedback. thanks
Old Mar 14, 2005 | 03:29 PM
mattd17's Avatar
mattd17
i too like you have researched almost every brand out there. i have heard a lot of good about superlift, and a lot of bad about pro-comp. i guess if you really want to spend a lot of money, then donahoe racing is about as good as they get. myself, i will probably be doing the 6" superlift with 37's as well. my only major decision right now it to go with the 6", or the 8". good luck !!
Old Mar 14, 2005 | 03:35 PM
ridered29's Avatar
ridered29
Just put on a 10" superlift and like what I see so far. I haven't heard much about some others. One important thing I would suggest is unless you are doing it yourself I would definitely look close at the shop you are using. I had a bad experience with one, but good with another.
Old Mar 14, 2005 | 03:48 PM
Yeti's Avatar
Yeti
Be prepared to possible modify your plow frame with a 6", depending on what kind of plow you run.
