1988 Ranger will not start
Old Mar 14, 2005 | 01:54 PM
jdeck00's Avatar
jdeck00
1988 Ranger 2.9L V-6/Automatic 2wd regular cab
123,000 miles
Bought the truck a couple of weeks ago had the dreaded lifter tick. Started and ran good but made a lot of noise. This weekend I pulled the valve covers off and reset the valve lash (0 lash and then 1-1/2 turns) put it back together with new dist cap/rotor, plugs & wires. Old plugs were black and sooty. Several plug wires came apart while removing. Contacts on cap and rotor were heavily worn.
Did NOT remove distributor or adjust ignition timing.
Truck will not start. I will turn over until the battery is dead but no signs of life. I have good spark and appears to have fuel (will check pressure tonight). It does backfire and shoot flame out of intake pretty often while cranking. No codes were stored.
Checked to verify plug wires were in proper firing order. rotor in distributor turns while cranking engine.
Any ideas or thoughts on what could be causing the no start condition.
Old Mar 14, 2005 | 03:24 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 14, 2005 | 06:37 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Are you 100% sure the wires are in the right spot, and the plugs are gapped properly? Also did you replace the coil?
Firing out the intake would tell me that the the ignition is trying to fire when the intake valves are open. This would not be a good thing. Check, and then re-check your wires.
Old Mar 14, 2005 | 07:52 PM
Ken00's Avatar
Ken00
I have to agree, check those wires.
Also you can go 1.75 turns on the valves, Ford put a TSB out on this years ago.
Old Mar 16, 2005 | 11:05 AM
jdeck00's Avatar
jdeck00
I re-checked the firing order, book says 1-4-2-5-3-6 and shows cylinder order as 1,2,3 on pass side of truck with 4,5,6 on drivers side of truck. Can anyone confirm this info?
Thanks
Old Mar 16, 2005 | 07:07 PM
Ken00's Avatar
Ken00
You are correct, 1 is the front passenger side.
