Steering Column Problems
Has anyone ever replaced an Airbag Sliding contact in a Bronco 94(SRS Steering wheel) if so where does the black wire with the brown semi circle clip
(small metal contact ) plug into. The old one was not connected/duct taped and I'm going nuts tryin to find out what this connects to Please Help !!!!!!!!!!!!!!!!!!!!
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy....and
Airbag wiring is bright yellow; so I think it must be the horn lead or the cruise control lead. The Airbag clockspring is identical for all Ford trucks - it has wires for the cruise, airbag and horn, even if your truck didn't come with cruise control. You need a wiring diagram to determine which one it is. Remember to disconnect the battery 1/2 hour prior to working around the airbag. If you're not comfortable with this device, you may want to leave repairs to a certified shop.
