2.9 Won't Start
Old Mar 13, 2005 | 03:05 PM
Boss50's Avatar
Boss50
2.9 Won't Start
I bought a 1986 Ranger 2.9V6 yesturday. I went and looked at the truck 2 times and it started perfectly. The owner said he had driven it around before I came both times so the engine was slightly warmed up so each time I tried it fired right up. I brought it home and let it sit for about 5 hours and went to start it and all it does is crank and crank and crank. The last time I started it I needed to pump the pedal a few times to get it to fire, but now I have no fire at all. Any ideas on what to look for???
Old Mar 13, 2005 | 03:30 PM
Ken00's Avatar
Ken00
The best places to start is checking for spark, testing the fuel pressure and pulling the codes.
Old Mar 13, 2005 | 04:48 PM
kvmch's Avatar
kvmch
stalling thread
I think we are having the same problem. Check out this thread. I have a 1987 Ranger 2.9, doing the same stuff as your truck.
Old Mar 14, 2005 | 11:52 AM
Boss50's Avatar
Boss50
I checked the fuel pressure, seemed good. I sprayed a LITTLE starting fluid in it and it didn't even fire once so I'll take a look at spark tonight.
Old Mar 14, 2005 | 06:16 PM
Boss50's Avatar
Boss50
My dad got it running today but it wouldn't start back up after he shut it off. He checked the fuel pressure and a bunch of air came out. Would that mean that there's a hole in the line that goes into the tank or something else??
Old Mar 14, 2005 | 07:46 PM
Ken00's Avatar
Ken00
Sounds like the check valve in the pump is letting the fuel drain back into the tank or the low pressure pump is not working properly.
How did you check the fuel pressure the first time?
How much gas do you have in the tank?
You truck has two pumps, a low pressure pump in the tank and a high pressure pump on the frame rail. When you first turn the key on the pumps will run for a few seconds, see if you can hear both of them.
Hows the spark?
Old Mar 15, 2005 | 06:17 PM
Boss50's Avatar
Boss50
I checked the fuel pressure by pressing that valve on the fuel rail. It has about 1/4 tank of gas, and it has good spark. I got zapped pretty good. I heard the pump on the rail turn on while we were checking the spark, also I don't know if I mentioned this or not but once while I was driving it started to spit and sputter like it was running out of gas but it stopped after about 15 seconds.
Old Mar 15, 2005 | 06:20 PM
Dave257's Avatar
Dave257
Sounds more and more like a fuel problem, coud be just a filter, but best to get a reading on it with a fuel pressure meter.
Dave
Lovin7.3
66
Dec 10, 2008 07:53 PM
DubDub
19
Jan 28, 2008 04:36 PM
flatheadfreddy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 7, 2004 07:49 AM
Chris89lx
Bronco II
13
Apr 18, 2004 10:00 PM
motorman
Bronco II
Mar 27, 2004 09:35 AM
