Belching Power Steering Pump
Old Mar 13, 2005 | 05:43 AM
jowilker's Avatar
jowilker
I thought I'd post and run this by the best minds in Ford country. My ps pump is pumping fluid out of the filler tube, and at a pretty fast drip rate.
I have a mid 70s Ford gear and a reman small filler tube pump ( fits under the bracket, & on a FE engine). I am not sure at this point if something is gummed up in the gear that is causing the pressure to insrease enough to flow out, if the sealing power of the dip stick is gone, or if the pump is going south.
What's your thoughts?
John
Old Mar 13, 2005 | 07:18 AM
barry's Avatar
barry
It shouldn't pump fluid out at all, obviously. THe cap or stick doesn't really seal the opening. Is the fluid at the correct level? It could be an air pocket or maybe the relief valve is stuck. At rest, it just should circulate fluid. I'd try another pump. That one definitely has problems. Rebuild kits are really just re-seal kits, so that won't help your problem.
Barry
Old Mar 13, 2005 | 07:27 AM
banjopicker66's Avatar
banjopicker66
John, if you want to go with the later pump, you can. I put the smaller, plastic bodied one, with the large fill hole on my '76 390. It was from a '78 with a 400M. I had to change out the pressure hose for the '78 version, but that's all.
Whether it is the pump or the box, I really don't know. I would like to learn what you discover, though.
Old Mar 13, 2005 | 07:56 AM
jowilker's Avatar
jowilker
I started to leave one morning recently and had no power, I had to add quite a bit of fluid and things started working again. I'm confused when I found it pumping out the top. That should mean that pressure is building up inside the pump body, and I didn't think that should happen.
I recently changed engines in my Taurus truck and was watching in the large opening pump that we were refilling, that the fluid was just being circulated with no noticable pressure build up.
thanks
John
Old Mar 14, 2005 | 05:47 AM
jowilker's Avatar
jowilker
Were is all of the experts when ya need one?
John
Old Mar 14, 2005 | 02:02 PM
William's Avatar
William
Cracked or leaking line, sticky pressure relif valve. I'd change the fluid and refill with new.
Old Mar 14, 2005 | 04:25 PM
Major1095's Avatar
Major1095
I recently put power steering on my 66. It is nice with one exception. When I have the front end jacked up with wheels off the ground and turn the steering wheel with out running the engine, it pumps fluid out the cap. I have asked several "mechanics" and they all say that is OK. Any comments.
Old Mar 14, 2005 | 04:44 PM
barry's Avatar
barry
NO, it shouldn't pump fluid out when it's shut off. The relief valve is supposed to keep fluid circulating thru the pump when the wheel is at "rest" so it doesn't pump it all back into the pump, causing a overflow. Yours is doing the same thing only when it's shut off. I think the valve is supposed to "center" itself at idle or shutoff, creating a loop so fluid just flows in one big circle. If it sticks, the fluid can't circle and has to find the path of least resistance and out the cap it goes. The plastic pumps are easy to swap, I'm uncertain on the metal can pumps how they're changed.
Barry
Old Mar 14, 2005 | 06:05 PM
banjopicker66
Barry, the plastic ones are bolted up the exact same way as the metal cannister ones. In fact, as far as I can tell, they aren't any different in the results they produce.
I replaced a cannister one in a '76 F-150 (from a 390), with one from a 400 out of a '78 F-150 with no problems.
The only change I had to make was the pressure line, because the '78 line had a swivel joint on the side, but the '76 cannister type had a typical pressure fitting.
Old Mar 14, 2005 | 07:57 PM
barry's Avatar
barry
Yes, they bolt up, it's the fitting with the relief valve in the old style pump. I think they come out the same way. The plastic pump are all the same except for the fitting and which way the return line goes on the body. Some point down, some go out the back. I swapped a plastic pump off a 93 Taurus 3.8 and put it on a 89 F-250 5.8 and all I had to do was swap the relief valve on the back. We used to do this at the dealer. I stocked 2 different parts numbers and made them fit all the cars and trucks.
Barry
robandrhonda
13
Apr 21, 2020 08:48 PM
95schauf
Feb 10, 2013 10:00 AM
Roy C
Nov 25, 2009 12:19 PM
abnjumpmaster
Jun 24, 2006 01:22 PM
ROOFGOOF
May 5, 2006 04:26 AM
