crewcab frame measurement
Old Mar 12, 2005 | 11:58 PM
cnelson's Avatar
cnelson
Thumbs up crewcab frame measurement
I just bought a 79 f250 crewcab 4x4 and the frame has been broke in two places and cut and spliced in two more. I'm buying another f250 4x4 from a salvage yard (regular cab). I plan on just using the rear of the regular cab frame to fix the crewcab frame. Can someone with a crewcab 4x4 give me the measurement from center of front hub to center of rear hub? I would appreciate it. Thanks.
Old Mar 13, 2005 | 03:38 PM
tjay460's Avatar
tjay460
The owners manual for my '78 F250 CC 4x4 lists the wheel base as 150.3". This measurement looks reasonable when measured with a tape. I don't know if the '79 is the same. Hope this helps
Old Mar 13, 2005 | 04:35 PM
Slow's Avatar
Slow
You probably already know this, but you have to watch your years here too..my understanding is that the frame is different in 78/79 from the earlier models (the "highboys").
I have a 76 CC. If you need me to I can measure it up, but it might be a slightly different length from the 78/79.
Ian
Old Mar 13, 2005 | 10:59 PM
cnelson's Avatar
cnelson
I don't think my frame is actually a crewcab frame. The VIN tag on the door says the cab was a 2wd but the frame is definitely a 4wd. And it appears the last two body mounts for the rear of the frame were added later. They're just welded on. Plus it appears the frame has been cut and stretched. I'll start with the first measurement of 150.3" and if someone else has another measurement i would like to know it also. Thanks.
Old Mar 14, 2005 | 12:33 PM
78250crewcab4x4's Avatar
78250crewcab4x4
my 78 250 crewcab measures 150 10/16 in. center of hub to center of hub and the frame is 222 in. long I have mine taken down to the frame right now so it is easy to measure
Old Mar 14, 2005 | 04:46 PM
cnelson's Avatar
cnelson
Thanks i really appreciate it.
