Heater that flames on.
Old Mar 12, 2005 | 10:30 PM
Dave Reardigan's Avatar
Dave Reardigan
Ok. Somebody tell me about a heater that blasts hot air as soon as I turn the key. canadian winters can make warming up a half-hour afair, someone give me a hair-brained idea for warmth. I've already considered a kerosene ready heater bolted to the floor in the box with an A/C power inverter and the slider open.
Old Mar 13, 2005 | 09:46 AM
Ultramagdan's Avatar
Ultramagdan
Why go through the trouble of a kerosene heater when a electric heater would work just as well and be a lot safer? A simple hair dryer would give a good idea of how much heat could be produced.
Old Mar 13, 2005 | 11:59 AM
Steina's Avatar
Steina
CO River Rat
Corvairs had gasoline-fired heaters, but finding one at a wrecking yard might be tough.
Steve
Old Mar 13, 2005 | 12:04 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
use a block heater. plug it in all night and you'll have heat real soon.
Old Mar 14, 2005 | 12:29 AM
460f250's Avatar
460f250
You can also use one of those in-line heaters that fits into the heater hose or rad hose. They heat and circulate, giving you warm air right away.
Old Mar 17, 2005 | 04:41 PM
Dave Reardigan
Wink
Good Idea. I don't think the DC power in a vehicle could produce decent results. The DC/AC power inverters are getting better but they're not that good. A standard hair dryer can pull about 1500 watts which isn't enough. You must be from Florida.
Old Mar 17, 2005 | 04:44 PM
Dave Reardigan
Not even remotely soon, sorry. Before I had a garage, I plugged in all night every night; no heat.
Old Mar 17, 2005 | 04:47 PM
Dave Reardigan
Thanks, but these things only keep the coolant "slightly" warm for easier starting. I still have to wait and patience is not my strong suit. Thanks for the reply.
Old Mar 17, 2005 | 04:49 PM
Dave Reardigan
Steve
Thanks, I think the old beetles had those too. I will definitely look into it. I wonder where I'll be able to locate the unit.
Old Mar 22, 2005 | 03:37 AM
A_Fire_InsideR1's Avatar
A_Fire_InsideR1
use an electric space heater, rig one up to plug into your cigarrete lighter or something, cant be that hard, theres probably products already like that on the market
Old Mar 22, 2005 | 05:39 PM
Dave Reardigan
If it "can't be that hard", you do it and tell us all about your fabulous success. Be specific too, with estimated BTU/hr , power requirements CFM from the blower, and last but not least, the dimensions and practicability of your unit. Thanks for the reply, I can hardly wait.
Old Mar 22, 2005 | 09:15 PM
midlf's Avatar
midlf
He He do the math - 1500 watts - 125amps @12v - And I doubt if 1500w will fit the "blasts hot air immediately" criteria in a Canadian Winter.
Old Mar 23, 2005 | 06:13 PM
Ultramagdan
I'm surprised you are not getting heat right away using the preheater. With a good preheater and an electric fan (or at least a really good fan clutch) it should warm right up. A half hour sounds excessive under any condition if it's being driven. Even with sub-zero temps here, a vehicle warms up pretty quick if it's driven.
Old Mar 25, 2005 | 10:03 PM
Dave Reardigan
Thanks for the reply. I just through a number out there (1/2 hour) to make a point. I honestly don't know exactly how long it takes, but even with the motor running for a long time I'm still chilly. I really appreciate your reply and I will check out some of the suggestions I got. Thanks again.
Old Mar 26, 2005 | 11:20 AM
midlf's Avatar
midlf
The gas fired heater on old beetles was a rare option. I would not trust using one that old unless it was in mint condition.
