Aerostar Ford Aerostar
Update to 95 AWD
Old Mar 12, 2005 | 08:45 PM
Muffinman's Avatar
Muffinman
Update to 95 AWD
Changed Oil and filter, Changed Plugs.
Flush cooling system.
Changed battery with my new one.
Changed rotors and pads with my new ones,
Greased all fittings, Bearings, Hinges and latches.
Changed wheels and tires with my new ones.
Washed, Steam cleaned and waxed it.
Sprayed under coating.
Repaired right front blinker lens, and washed out those dull *** headlight lens.
Changed PS pump and flushed hoses.
I am now going to fall down cause I can't move anymore
Old Mar 12, 2005 | 09:30 PM
copper_90680's Avatar
copper_90680
I just did the front brakes and I'm already tired. Damn it! Old age is a cursed thing
Old Mar 12, 2005 | 09:52 PM
Muffinman's Avatar
Muffinman
I still got the bulbs to replace, Install my inverter, Change the compressor with my new one.
The last thing is remove my Alpine HU, Amp, Speakers, Fuse block, Distribution block, All the wiring, then turn around and install it.
Is Monday a holiday, I think it is. Yea Holiday thats it
Old Mar 12, 2005 | 10:01 PM
93nighthawk's Avatar
93nighthawk
So where are the pics of this newly cleaned beast?
Is Monday a holiday, I think it is. Yea Holiday thats it<!-- / message -->
Ok, I missed something, what holiday?
Old Mar 12, 2005 | 10:08 PM
Muffinman's Avatar
Muffinman
I will post some of them after is all done.
Some of the old with the old parts and the new completed One. Then I will start the tranny project when all my joints get some lube back in them.
Did I also say I put the old parts back on the old one too. Thats the back breaker.
Old Mar 13, 2005 | 08:22 AM
Muffinman's Avatar
Muffinman
Well I forgot the Alt on a 1990 will not fit a 1995 and I'm not cutting to make it fit. So one of the Alpine Amps has to stay disconnected till I can get a 160 Amp Kit.
