Colant System Pressure Test
Old Mar 12, 2005 | 05:29 PM
Weasel's_Truck's Avatar
Weasel's_Truck
I am Losing Coolant.
I put my pressure tester on the the radior today and the air bubbles up through the radiator any ideas why this is????
Old Mar 12, 2005 | 05:44 PM
Steina's Avatar
Steina
CO River Rat
Do you get bubbles in the radiator with the engine running? What year, truck, engine are you testing?
Steve
Old Mar 12, 2005 | 05:56 PM
Weasel's_Truck
No no bubbles comming back while the engine is runningas soon as i turn the engine off the coolant will flow out of the radiator. and it is a 96 Explorer 4.0
Matt
Old Mar 12, 2005 | 05:59 PM
Weasel's_Truck
Sorry sorry sorry. just read my first post and there was an error the when i pump the tester the ther bubbles are through the resavour not the radiator
Old Mar 12, 2005 | 09:34 PM
midlf's Avatar
midlf
The pressure tester is not correctly sealing to the radiator neck. If the pressure tester does not seal, the radiator cap also may not seal. Take a close look at the neck and the sealing surfaces to see if that is the problem.
Old Mar 13, 2005 | 02:05 PM
Weasel's_Truck
Got it. The Butterfly on my heater valve broke and was cloging up the system. Coolant was then leaking out of this valve fwiw
