Towing capacity
Tell us more about where you are, what truck, hitch type, all the info you can send.
4 X 1400 = 5200lbs, trailer is about 2800lbs so on the high end we are talking 8000lb load. Many versions of 99 F250s will handle this but obviously not win any race to the top of a 11,000 foot mountain.
If you trailer form Abilene to Midland it don't matter. All flat land and no need to beat feet to the next rodeo.
But if you need to cross all of Colorado in route to Wyoming you may have a tough time and very stressed out horses!
Towing capacities are different based on the cab configuration, drivetrain (2x4 or 4x4) tranny type and if you want a tow behind or 5th wheel trailer.
I'm figuring it's gonna be a goose-neck (5th) wheel since I don't think I've ever seen tow behind 4 horse trailer.
You're gonna want to stay around or below the 10K range. And quite frankly, if it's gonna be that much weight, I think you'll be dissapointed with the power of that '99 w/3.73s.
Check out the FTE's Super Duty FAQ for more info. Keep in mind that the quoted weight capacities are for 00 and up. Things shouldn't be too much different for your 99.
hehehehe....just playin' guys.
_____________________
Moderator note.
"This thread was merged with a duplicate post."
Thanks for catching it Capt.
Here are some suggestions assuming your truck is an auto tranny.
Get a good trans oil temperature gauge. Consider adding a inexpensive auxilery trany oil cooler. Keeep the fluid tems below 200F and if you spike over 208F briefly don't get freked out but watch it carefully and slow down and lock out OD for sure. Any time over 220F will require the fluid to be changed out and if you go more than a few minuets at that temp your trans will puke the front seal and start peeing fluid every where.
Set up a good brand trailer brake controller and get your horse trailer brakes checked out and refurbished as needed. Make sure the wiring is perfect and all grounds are to bare metal, no rust or corrosion.
Set out on your trips in Over Drive (OD). When you get into the hills the trans will start to do a lock unlock of the troque converter when it becomes unhappy with the load and gear. This locking and unlocking is usually not felt but can be seen on the tach as a slight increas in rpm about 50 to 175rpm raise. When this happens the trans temp will rise due to the torque converter now slipping. On steeper hills the trany will do a dramatic down shift. My passengers don't like it so I am sure your horses won't appreciate it either. When this happend just push the OD button on the shift lever and that will LOCK OUT the top gear OD and let the trany automatically only shift up to HIGH gear and any lower gear. When necessary deliberatly down shift one gear to climba steep section.
This will cause you motor to spin up climbing the mountains and this is OK! The V10 will run all day long at 3800-4800rpm and not hurt any thing but MPG. The motor has plenty of power up there and should pull that load up most any steep mountain pass.
If you find that the truck really struggles you have a couple of options to get more power to the ground.
Montana is not too dusty and sandy so I can recommend a K&N air filter. I don't think the FIPK is worth the money. Just do the ZooDad mod... search this forum for ZooDad.
There are some exhaust mods you can do to compliment the extra intake air at higher rpms. You can get a chip, but you will be forced to premium fuel and the cost of it.
Re gearing the two differentials is a LOT of $$$$. You can effectivly reduce your final gear ratio by putting on a smaller set of tires... 235R7016 E rated will fit and give you more towing torque. These trucks are popular and a lot of guys get new rims so finding a second set of factory rims is easy and cheap... think about getting a second set and small tires then you can have tow hunting rims and tall every day empty highway rims.
Well that is a start and I am sure you will have more questions. This is not a complete list of things to be done.
Over the years we got out of the horse ownership as being a soldier causes too many mooves and temp paddoc and vets bills were eating our lunch!
Back to the truck thing. I try to convince every body that will listen that trailering horses is very stressful on them. Being a smooth driver is part of keeping them happy but I learned another truth:
Get a good quiet muffler. THey calm down much faster after a trip if they did not have to listen to a constant loud bunch of noise for hours on the road!
To amplify it I spent way too many years (and still do) riding motorcycles and had the erronious belief that "loud pipes save lives". I no longer subscribe to this idea. Keen awarness and excellent knowledge of your equipment, skill, and no alcohol are much better alternatives. Additionally many annoyed other drivers cause more and more noise abatement laws and they have the potential to cause us to someday NOT be allowed to tinker and modify.
And Ronin007s observation is also true, 4 to 8 hours on the road in a loud vehicle is infinatly more stressful than the same trip in a comfortable, quiet vehicle where you can here normal conversation or enjoy ZZ Top at a comfortable sound level.
OK off soap box...... I am NOT the noise police... just an opinion and some food for thought
Back then most of my race vehicles were also my DD. After a couple of hours on the road with straight pipes or small glass pack mufflers you would get out of the vehicle with your ears ringing and everyone telling you that you are yelling. About the only good thing about it was it saved me money on sound systems as you couldn't hear them over the din of engine!!
Now like Fred, I keep the exhaust noise down and can enjoy conversations with my passengers along with whatever tunes we choose to listen too.
I had them custom made by a friend who owns an exhaust shop on my car.
When you are on a long trip (or want to be quieter), just push the button on the dash to activate the solenoid, it now directs all exhaust gas through a muffler, push the button again to rip the eardrums into 2.
