Sponsored by: Real Truck
Hub staying locked
Old Mar 12, 2005 | 02:10 PM
mizzitch's Avatar
mizzitch
Hub staying locked
I have a 1999 with ESOF and the passenger hub likes to stay locked after the 4x4 is turned off - even if I back up. I had the hubs either serviced or replaced three years ago. If I put it up on a lift and tap the lockout it will release. What is the fix for this? (I like not having to get out to lock hubs - so warns are kinda out of the question.)
Old Mar 12, 2005 | 04:09 PM
99f350sd's Avatar
99f350sd
New hubs.??? Check your bearings a worn bearing will cause the axle to bind in the hub. You may be able to take em apart and clean them. Most people are tossing them for warns..
Dick
