under the hood behind the air box driverside there are 3 relays and an eec test plug. the relays are labeled and i think the middle one is the fuel pump relay. i would tap on the relay with the back of a screwdriver. if that does not help then i would go and find the inertia switch and check to see if it has been tripped. if this is not the problem now it is time to check the wiring to the fuel pump.
when my fuel pump went i was able to tap on the tank with a piece of WOOD and the pump started and i was able to make it home. good luck and let us know how you make out.
