trans fluids
Old Mar 12, 2005 | 06:42 AM
o'berry farms's Avatar
o'berry farms
Exclamation trans fluids
Anyway my main question is what type of trans fluid does the C6 take cause the dipstick says type F but a repair manual I have says DexronIII ATF which is right cause im getting confused .
Also,I have a 76 ford. The man i bought it from told me it has a 390 and a C6 but the engien has 32 352 stamped on it if anyone can tell me what this means that would be nice.
Thank you this help is greatly apprecated.
george
Old Mar 12, 2005 | 06:55 AM
2020's Avatar
2020
In a 76 the Dexron will be OK.All FE engines had the 352 cast into the block.The clutch material is the reason for the type F fluid in the pre 71 trannnys.They changed it in the later trans.
Old Mar 12, 2005 | 06:57 AM
o'berry farms
thank you for this insight
Old Mar 12, 2005 | 09:37 AM
TRaGiK's Avatar
TRaGiK
Also, if an early model has been rebuilt, you can use dextron safely. Rebuld kits use newer clutch material.
Old Mar 12, 2005 | 12:11 PM
Mil1ion's Avatar
Mil1ion
I don't blame you for being confused.
C4's used Type F.
C6's used Dextron II & Higher
Engine related questions can be asked in the Engine forum pertaining to which engine you are asking about
Old Mar 12, 2005 | 12:43 PM
o'berry farms
thank you the dip stick must be from a C4 because the C6 gasket matches the pan on my tranny
Old Mar 12, 2005 | 12:49 PM
ford390gashog's Avatar
ford390gashog
well in my book it says up till 79 use type f then from 80 forward use mercon
and a c-4 dipstick won't fit so you have the right one all c-6's used type f until 1979
Old Mar 12, 2005 | 03:39 PM
Mil1ion's Avatar
Mil1ion
Okay, after further research 77 & newer C6's require Dextron II
76 C6's require Type F.
I had to dig deep to find that.
Sorry about the mis-info.
Old Mar 12, 2005 | 09:46 PM
o'berry farms
ok thank you all cause my trans is actting like it has lost a gear and and it has more fluid in it than normal and the last time i put some in was maybe december at the latest im going in tomarrow to see if i find out what is wrong thanks for all the info i wanted to make sure i had been useing the right fluid.
Old Mar 12, 2005 | 10:20 PM
Mil1ion's Avatar
Mil1ion
Which gear ?
Adjustable Modulator valve ?
Due to the drift of the discussion this thread will be moved to the drivetrain forum.
Old Mar 13, 2005 | 09:51 AM
o'berry farms
it seems to have lost second gear
