I need the tourque specs for the rod bearings/ main bearings/ and head for the 300 I6. I just put a new set of rings in and replaced number 5 piston, re-installing everything and hope someone would take a peek in their manual for these specs....This truck is 1985 F150 4X4 Thanks Brett
Connecting Rod Nuts - 40 to 45 Ft-lbs
Main Bearing Cap Bolts - 60 to 70 Ft-lbs
Cylinder Head Bolts:
Step 1........55 Ft-lbs
Step 2........65 Ft-lbs
Step 3........85 Ft-lbs
