Computer settings
Old Jun 21, 2001 | 11:04 AM
deere81's Avatar
deere81
Computer settings
I recently swapped out the old 302 in my '90 F-150 and put in a 351. How long does it take the computer to relearn everything. It was running really rich and using a tremendous amount of fuel. Or do i need to make some adjustments on the EFI?
Old Jun 21, 2001 | 04:14 PM
rahal's Avatar
rahal
Computer settings
i have done the same swap to my 96 f150 , i swaped the 302 and put in a 96 broncos 351w, to ny information , both engines has to have the same firing order, efi system( speed density,or mass air) and you will be all right for the swap,the only difference that might be with the EEC is that the 5.8 will require more fuel than the 5.0 ( you may run littel lean and not as you are saying ,RICH) but this can be solved by an adjustable fuel pressur regulator and a set of larger fuel injectors, or one of the programable chips can compensate for that , good luck,
and keep me informed if you need any information that i can help with.
Old Jun 22, 2001 | 12:02 AM
PAUL_2's Avatar
PAUL_2
Computer settings
What yr engine is the 351 ? Youll have to use the Ecu from the 351 .
Old Jun 22, 2001 | 01:05 PM
nickc84's Avatar
nickc84
Computer settings
