King Pins
Old Mar 11, 2005 | 09:47 PM
RDON's Avatar
RDON
Cool King Pins
I think that I am going to have to have the King Pins replaced on my 77 F250 Lots of movement.
Has anyone had this done lately? Sure would like to know what dollares I'm looking at.(calif)
Old Mar 11, 2005 | 10:31 PM
docholiday72tx's Avatar
docholiday72tx
I did mine my self and spent a little under a hundred between buying parts and haveing the bushings pressed in and machined for my pins.
Mike
Old Mar 12, 2005 | 10:14 AM
ivanribic's Avatar
ivanribic
Doc's estimate sounds about right. Most of the kingpin kits run around $50 for the parts themselves.
Old Mar 12, 2005 | 11:24 AM
oldhalftons's Avatar
oldhalftons
It cost me $40 for pins with metal bushings and $140 to have the old pins pressed out and the bushing reamed for the new pins.
Old Mar 12, 2005 | 05:31 PM
docholiday72tx
One word of advice....If you choose to change your own pins, make sure to have a big hammer, a ton of patience, and a realy good set of gloves. If you don't have good gloves you probably won't live long enough for the blisters to heal. It took me about a half a day to beat mine out. Those buggers are in there tight.
Some people heat them up with a torch to make it easier, but I don't use heat on anything connected to the frame. It's realy a matter of opinion......I'm just a little overly picky on frame, suspension, and steering parts.
Mike
Old Mar 12, 2005 | 09:25 PM
RDON's Avatar
RDON
Thanks for the information. Not being a machnic it is something that is to critical for me to attempt.So I was just wondering what to expect.Some kind of ball park figure
Don
