front end squeeking
Old Mar 11, 2005 | 08:48 PM
99FordF350's Avatar
99FordF350
front end squeeking
my front-end started squeeking about six months after 2" add-a-leaf installeded. anyone with this problem or how to fix any info would be great.
by the way its a 99 F-350
Old Mar 11, 2005 | 08:53 PM
Quadzilla's Avatar
Quadzilla
My son-in-law has a 99, and it used to have the same problem. There are nylon bushings that are supposed to be between the leaves in the front suspension. His were worn down to the point that the leaves were actually in contact at the ends, where the bushings are supposed to be. We replaced the bushings, and the sound got considerably better. He wound up replacing the shocks, and the rest of the sound went away.
I hope this helps.
Old Mar 11, 2005 | 08:58 PM
f350galaxie's Avatar
f350galaxie
Check those leaf pads, and you may also want to have your local spring shop rearch the add-a-leaf to fit. Sometimes aftermarket add-a-leafs have a very high arch to them. The leaves should all have the same arch to them.
Old Mar 11, 2005 | 09:36 PM
99FordF350's Avatar
99FordF350
i never thought about it i had dual shockes put on it could be them. have to do some checking tomarrow
Old Mar 12, 2005 | 01:38 AM
MRBASS's Avatar
MRBASS
When i installed my add a leafs i covered the springs with grease before i installed them, both sides and the bottom of the factory leaf too. Thats been about a year ago and no squeaks yet..
Old Mar 13, 2005 | 09:37 AM
99f250's Avatar
99f250
how about a clunk? could this be the same problem?
Old Mar 13, 2005 | 09:54 AM
Quadzilla's Avatar
Quadzilla
My son-in-law found that his clunk got better with the new bushings, but new shocks made it go away completely.
Old Mar 13, 2005 | 08:01 PM
99FordF350's Avatar
99FordF350
99f250 the clunk could be your track bar bolts are alittle loose letting it move slighty
Old Mar 13, 2005 | 08:11 PM
99f250's Avatar
99f250
cool---i need to go thru the front end and tighten things up i think......
