Tranny
Old Mar 11, 2005 | 05:18 PM
Carterdsc's Avatar
Carterdsc
Cool Tranny
My daughter has a 1994 4X4 Ford Ranger. It has an automatic transmission. The problem is, it is slow shifting from 1st to 2nd. If I let off the gas, it will shift then I can apply the gas and we're off in 2nd gear. From there on up it shifts fine. Going up a hill makes it tough to do this accelerater shuffle. Not sure it needs an overhaul. Could it be a seal or modulator problem. I don't really have $1600 to $2000 to spend for a tranny overhaul. Any insights would be helpful.
JD
Old Mar 11, 2005 | 07:42 PM
Ken00's Avatar
Ken00
Welcome to FTE!!
I would suspect the modulator or cable adjustment.
Old Mar 11, 2005 | 08:50 PM
rangerchief's Avatar
rangerchief
I have a 2001 that seems to do the same thing. Would that be what to check on a 2001 or is that trannie all electronic?
2001 4X2 3.0L
TIA
Old Mar 12, 2005 | 07:22 PM
Ken00's Avatar
Ken00
I would suspect low line pressure, leaky valve body or a VSS going out.
