is 2.9L really that bad?
i had an 86 b2 4x4 with a 300 straight 6 and 5 speed trans. it had 200,000 plus miles of neglect and sever abuse when my uncle finaly sold it to me. when i got it,the proper mantainance was started, but it still got some pretty heavy abuse. i laid it on its side twice in one day, climbing river bankes. drove it in the river up to the head lights on a regular bassis. i tryed for a year and a half to kill it and couldnt. the worst i could do was burn up two ram clutchs. burnt the first one up in a push of war in a mud pit. {still won though.} lost the second one pulling a z71 out of the mud, he tryed to follow me after every one there worned him not too. {that second clutch was worth every penny} .it never once got stuck, and it always got me home. guess what im trying to say is ,its a ford, beat it ,bash it and abuse it , then servise it . it will last when nothing else can or will. WHEN IN DOUGHT, FORD POWER IT OUT!
Lucky117,take or leave this advice:If you're still in school and don't have a job yet,or even if you do find a job soon don't go too far with the Bronco upgrades.As you can see if you scan other posts the 2.9 and its systems have their problems and you can dump alot of time and money into something that just aint worth it.You're in metal shop which is great and you can use that skill to go wild on a project...maybe a 72 Bronco,but even us older guys have to save for along time to do a build and a good one will take years.Get your basics done on the 88 and make this your support vehicle:don't try to polish a turd too much.Start with something that has value/tried and true design,even if its just a frame,build a crazy buggy or mud tromper.Use an engine that does'nt require all the smog stuff.Master your skill
well. I am 16 have an 87 Bronco II. 2.9 5 speed 4x4 manual hubs. I just bought $200 in ignition upgrades and now my wallet is a bit lighter. I am putting my money into the piece to get the best out of it. this is to be a great offroad machine some day and i might as well start right. IS THERE ANYWAY TO CHANGE MY IGNITION CONTROL MODULE WITHOUT REMOVING THE DISTRIBUTOR???? I just got my Accel PCM, Accel Cap and Rotor, Accel Coil, Bosch Platinum2 plugs, and my Taylor Thunderbolt 8.2 wires should be here in 2 weeks because they were on back order.
#29
i went and bought a special tool for the module. put on all my new parts. ran good. now it wont turn over?...the battery has full charge and the terminal clamps are brand new. clean connections. the solenoid makes an odd noise so i tried one i have that i knew was good and its still doing the same thing?
#30
