when you consider that the newer trucks with the 4.6 v8's are nearly the same cubic inches as a 289 and weigh more than our trucks i would say without a doubt yes.
I would disagree. (Sorry 4 Cammer! I seem to disagree a lot, please don't take it personal!)
The 4.6 Triton is a 281 CI, yes, BUT and a very BIG BUT it has all the latest cam and valve and piston designs, with computer controls and fuel injection features which make it able to get more efficient power out of those 281 cubes than a carbed 289.
It is the entire system that makes it possible, not the cubes.
In pre-computerized engine days, yes, greater displacement was the primary if not the ONLY solution to more power. Today, you can do more with less.
But, displacement isn't obsolete.
If you need more power than the Triton 4.6 can produce, I doubt you will get it by refining the engine any further. The improvements have about reached their limit of refinement. You will need to get that power by increasing the cubes.
BANJO, i dont take much personal, i am just taking into consideration the weight difference between a 67 to 72 f series compared to a expedition or late model f series. you also need to consider gearing in the math of it. i dont see where a od trans could be a problem for everyday cruising.
Lots of guys in this forum have put AODs behind 302 with good success. I think the rear end ratio has to be matched so that you are not overdriving the little motor too much.
My 302/C4/3.25 will rev at about 2500 rpm at 60 mph. I would not expect that motor to be happy at anything under about 2200 rpm at 60 mph. The advantage of the AOD is that you can get a small reduction in highway rpms but you can also run a way lower rear end ratio for livelier acceleration.
I think I was interpreting "...has the power to move...." a little differently. I was thinking "..power to move fast off the line" or "..go fast soon" kind of power. Also I was assuming he would be using a mid-60's 289, pretty much stock.
Yeah, the 302 w/AOD would be a decent combination, with a low enough gear ratio. I didn't really consider that. Windsors really prefer higher RPMs than FEs or 385s to work well.
Even so, in a truck it wouldn't be a real peppy or powerful combination, I would think, but you could work it to get good fuel mileage.
Thanks for qualifying the useable parameters.
thank you guys,im happy that i got answers i could actually use. the 289 is out of a 66 f-100,i think,money,well,recently i have acquered a job that pays quite well,w/ lots of hours,so money at this point is plentyful,and i can spen it when i like....so thanx once again yall.
my experience wasnt with an f-series but with a 63 1/2 galaxie. lets just say sometimes it was hard to get out of its own way. i'm sure with enough money though we could have helped that, but hey i was a broke teenager at the time!
what size rear tire are you running and what have you done to the motor. remember these trucks have the aerodynamics of a brick, and unless the steering and suspension is in great shape they arent very stable at high speeds.
at the moment,it is a stock 289 out of a 66 f-100. the wheels i will be running will be 15 or 17,no bigger then that. right now my wheel size is a 15 inch rim.
