drivers window
Old Mar 10, 2005 | 07:20 PM
big bird 1's Avatar
big bird 1
drivers window
Hi all heres a stupid silly, some times when the window is going down( its elec)
the window wants to bind. it doesnt do it all the time and when it does it stops going down with 3 inchs still showing. i have had the door apart trying to see whats going wrong and just cant see whats causing it, any info would be great
its a 94 150 extend cab xlt
thanks joe
Old Mar 11, 2005 | 01:33 AM
92supercab's Avatar
92supercab
Check the slider that the rollers roll in at the bottom of the window. Any chance there is a screw or something sticking out of the door blocking the window. What about the motor? I would guess its in the slider, but you may want to check the gears also and lube the entire system.
Old Mar 14, 2005 | 01:04 PM
big bird 1's Avatar
big bird 1
ok went back in and looked one more time found what appears to be a broken piece of plastic mounted on the bottom of the right side of the window, could this be the problem? checked all the moving parts they seem find and every thing seems tight and in its place
