1985 Aod
Old Mar 10, 2005 | 06:53 PM
VvDELLvV's Avatar
VvDELLvV
1985 Aod
i have a 1985 F-150 with an AOD tranny. i recently had to rebuild it because it was slipping in 3rd and 4th. when i took it apart i found that the washer spring was broken. i thought that this was the problem because it was not letting the clutches apply. so i replaced all the clutches and the washer spring and put the tranny back into the truck. but the tranny still wont shift into 3rd or 4th. the only difference is that before i rebuilt it the tranny was slippin in 3rd and 4th and now it isnt slippin it is just that now the tranny wont shift. i know that the cluches arnt slippin cause i can power brake it with no problem. if any boby has any ideas of what it could be i would apperciate it
Old Mar 11, 2005 | 11:50 AM
85e150's Avatar
85e150
Sounds like another tweek is in order:
Read on, maybe they have something for you.
http://www.tciauto.com/ford/ford_aod.htm
http://www.transmissioncenter.net/AOD.htm
http://ckperformance.com/ford_aod.html
