please help me
Old Mar 10, 2005 | 02:49 PM
jimbob21rc's Avatar
jimbob21rc
Exclamation ABS light
i have got a 96 f-150 4x4 and the abs light come on so i checked it, it flashed 11 short and 1 long which indicates a code 12 which is low brake fluid but my fluid is fine, the reservior is full, what is the problem and how can i fix it.
thanks, jimbob
Old Mar 10, 2005 | 06:59 PM
tex94F250's Avatar
tex94F250
Question Rabs?
Have you checked your RABS?
Old Mar 10, 2005 | 08:43 PM
jimbob21rc's Avatar
jimbob21rc
yes, that is what i meant when i said i checked it, i conected a jumper wire to the orange/black wire and the other to a ground and the abs light flashed a code 12 which is either low brake fluid or brake fluid level switch is bad, where is the switch, the connector was under the passenger side dash under the glovebox.
Old May 15, 2005 | 11:00 AM
bcdeines's Avatar
bcdeines
do you have a plastic the reservoir? If so the switch is under the resevoir with three wires on it. One goes to ground, one to the ignition switch and the other to the rabs module. You might make sure the float inside the reservoir isnt sticking.
Old May 15, 2005 | 04:27 PM
jimbob21rc's Avatar
jimbob21rc
the float isn't stuck but i will check under the resivior. thanks,
jimbob7575
1997 - 2003 F150
Aug 29, 2007 12:11 AM
jimbob237
Feb 27, 2006 11:06 PM
jimbob21rc
User Gallery & Picture Display
Mar 11, 2005 10:19 PM
jimbob21rc
Mar 10, 2005 04:28 PM
