Sagging Doors
Old Mar 9, 2005 | 06:02 PM
LARIAT 85's Avatar
LARIAT 85
Sagging Doors
The doors on my 1985 Ford F-150 are sagging. What exactly do I need to replace or fix to get them to close crisp again?
Old Mar 9, 2005 | 06:25 PM
RyanMiller's Avatar
RyanMiller
change the hinge bushings( most auto part stores sell a kit)
change the striker bolt, the plastic useualy wears when the hinges sag.
and if you realy wanna get crazy, you could lube the latches with some graphite mabye?
Old Mar 9, 2005 | 07:08 PM
plowpusher's Avatar
plowpusher
check the hidges bt opening the door about 1/2 way then lift from the latch end watch the hindges for play there look at the door frame make sure its not rusted at the back post this will cause cab flex also
