On the 04 FX4 picture the center console if you will.
The bottom has a ashtray that u can open by pushing on it.
If i remove that and insert a cb radio will that void the warranty? Note that at know time will I be drilling any holes or anything like that. The ashtray can easliy be reinstalled if needed. The only thing is that everytime I go in for an oil change or something and they see that I took out the ashtray and replaced it w/ a radio.I dont want them to tell me the warranty is void because of it.
Different dealers have different policies about mods. But it shouldn't cause any problems as long as everything is wired and fused properly. If you're really worried about it, have a good car audio shop install it for you.
It won't void your warranty. As long as your mod is not the direct result of a problem (in that case they wouldn't cover it) But your overall warranty will be fine.
