F350 Springs For Excursion
Old Mar 9, 2005 | 04:11 PM
jamez's Avatar
jamez
Will F350 Front Leaf Springs Fit An Excursion? If So, How Much Lift Will It Give Me ? Will It Ride Worse Than Stock?
Old Mar 10, 2005 | 09:48 PM
Rcmoneypit's Avatar
Rcmoneypit
Yes, they'll fit. Amount of lift depends on what engine your Ex has and what spring code the F350 springs are. Do a search on front spring replacement chart. As how they ride seems to be a personal preference. Some people say too stiff, some say its much better. I have a set of F350 V code springs if you are interested. I also have a set of F350 rear blocks that some people install to give a small lift to the rear when installing the springs. I was going to do this, but ended up going with a bracket lift and new springs for the rear. I just wanted more lift than the springs and blocks offered.
Old Mar 11, 2005 | 06:43 AM
jamez's Avatar
jamez
I have a set of f350 x code springs . I looked at the ex springs and the bump stop is only 2" from hitting. I might be intrestested in the rear blocks .How big are they? I would like to fit a set of 33" tires on it.
Old Mar 11, 2005 | 11:57 AM
Rcmoneypit's Avatar
Rcmoneypit
I sent a private message.
