351m or 351w?
Old Mar 9, 2005 | 01:28 PM
helicon's Avatar
helicon
351m or 351w?
i recently changed the timing chain, water pump and harmonic balancer on my 79 ford f250 4X4, and all the parts matched as being for a 351m, but when i changed my oil pump and bought new gaskets for the oil pan, the modified gaskets didn't match up but the windsor gaskets did. i can't find any identification on the engine anywhere. how can i be sure what it is? thanks for the help
Old Mar 9, 2005 | 01:31 PM
dave74-360bb's Avatar
dave74-360bb
have you owend the truck since new?
if not some one may have changed it to a 351w
not sure if timing chains etc. are same but know starters alts. etc are all interchangeable
Old Mar 9, 2005 | 02:39 PM
GreenSubmarine's Avatar
GreenSubmarine
Count the valve cover bolts. If your engine is a 351W, it will have 6 of them - 8 if it's an M block. The heads are not interchangeable, so this test will tell you once and for all.
Ernie
Old Mar 9, 2005 | 02:44 PM
MBDiagMan's Avatar
MBDiagMan
The heads are interchangable but not without the use of special intake manifolds on each engine.
Valve cover bolts is the quickest and easiest way to know though, the likelihood of someone using a custom intake to use other heads is almost nonexistent.
Have a great day,
Doc
Old Mar 10, 2005 | 04:39 PM
helicon's Avatar
helicon
thnaks for the help - its an m
Old Mar 10, 2005 | 06:54 PM
GreenSubmarine
Thanks for the clarification, Doc. I should have been more specific.
Ernie
