Help with the braking system
Old Mar 9, 2005 | 11:18 AM
bubba_blue's Avatar
bubba_blue
I got a 1998 Ford Explorer 2 wheel drive with abs. I changed the brake rotor, brakes, and calipers on both side. I bled the brakes correctly but the petal still doesnt have and restriction. there isnt any air in the lines. the only thing i could think of is the master cylinder is having problems.
Old Mar 9, 2005 | 12:56 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 10, 2005 | 06:20 AM
marragtop's Avatar
marragtop
Did you have the pedal problem before you changed the calipers? Also, did you work on the front or rear brakes, and was the master cylinder ever completely dry?
Old Mar 10, 2005 | 04:53 PM
bubba_blue's Avatar
bubba_blue
I did the front brakes. There wasnt any problems before with the brakes till i did this.
Old Mar 13, 2005 | 04:49 PM
maa139's Avatar
maa139
When you replaced the calipers, did you put them on the correct side? The bleeder screw HAS to be at the top of the caliper. If it's not, you will never get all of the air out of the system.
Also, are the back brakes adjusted properly? Does the pedal get hard if you pump it a few times?
Matt
