460 swap
Old Apr 3, 2001 | 09:34 PM
snickers's Avatar
snickers
460 swap
I own a 1986 Ford E250 with a 351W. I have the opportunity to get a 1979 460 out of an LTD. Will I encounter any problems
putting in an older 460 as opposed to using a later model? My truck is carbureted. Is there a difference between the "car"
motor and the "truck" motor?
Old Jul 15, 2001 | 01:44 AM
sweet82's Avatar
sweet82
460 swap
If you go the 460 route youll need a diffrent trans because the 351w is a small block and the 460 is a big block you probally need a rear sump pan the ltd may have a rear sump but I think its a front I have seen front sumps in trucks but the oil drains on the cross member youll need a radiator,engine mounts,hoses ect
Rodney
LFLS
Old Jul 15, 2001 | 09:19 AM
Mattman1's Avatar
Mattman1
460 swap
Hey, I was putting a 400m out of a Lincoln into my 81 250. The smog pump had to be removed and set back to the truck set-up. It was mounted on the bottom and would hit the crossmemeber. The fuel pump had to be replaced with a truck pump as it would hit the crossmemeber also. I know that these are different than your setup but I thought I would give you an idea of what may be involved. Hope it helps?
Old Jul 15, 2001 | 07:34 PM
billyb's Avatar
billyb
460 swap
check L+L PRODUCTS for a complete list of their swap kits. ADVANCE ADAPTERS also has information.
Old Jul 15, 2001 | 08:17 PM
RubberDuck's Avatar
RubberDuck
460 swap
dboy1
New Member Introductions
Jan 24, 2014 10:07 AM
mjeas
Jul 7, 2011 04:27 PM
1stF250
Dec 5, 2006 01:32 AM
TheLastRebel
13
Oct 23, 2004 05:54 AM
ben blank
Oct 10, 2004 09:28 PM
