4x4 wheel bearings
What is the best way to see if your front (or rear) wheel bearing are shot?
Obviously, if they are loose, that is a good indication. However, the ones in my 4x4 don't have any play in them, but it seems like I have the inner lock nut cranked the whole way down (ie can't turn it any more with a 1/2" ratchet), and the wheel bearing doesn't bind up.
When I did my 2wd truck, I'd crank them down until I felt the bearing start to bind, back them off and snug them down.
I'm pretty sure the bearings are too loose, but I thought I'd get another option.
I taped over all the trim, took off the rear view mirrors, taped off the cowl, hood to fender line, door to fender line, blocked off the grille, stuffed insulation in the inner fender wall, took off the wipers, and went for a ride....Still there! even at 5 mph, what sounded like wind wiggling somthing around. And just before I put the '86 Stepside 4x4 away for the winter, I really listened and got a new clue...The "wind" noise would incerase and decrease with speed. Well of course you say,
But and the slower speeds around 5 or so, and you really listen with everything else off the "wind" had a resinence of the wheel rotation. Wish, wish, wish, 1 Wish per rotation! aint no wind noise! got to be a front break rubbing or a burnt bering or bad race.
Cant wait till spring and do rotor and berings!
I have to agree with Liam. It would be nice if there was a definitive test for bearing wear, but I think a good visual and press test for looseness is about all you can do. As cheap as bearings are, I suggest replacing them. In fact, buy a spare inner and outer to keep in the truck. Cause if you use it like a 4x4, and you have decent sized tires, you're gonna go through bearings. Water and mud are bearing killers.
All the Best,
Ernie
