engine swap question
Old Mar 9, 2005 | 09:49 AM
Jason7396's Avatar
Jason7396
yes i have a 1973 ford bronco with a C4 tranny and im wanting to bolt up a 1996 4.6L from a crown victoria in it and im wondering if the bolt holes from motor to tranny are the same ?
Old Mar 9, 2005 | 11:52 AM
MBDiagMan's Avatar
MBDiagMan
The earliest Lincolns and Crown Vics had the 302 bolt pattern, but I don't know at what year they changed. If the car you got the block from had an AOD transmission, then the bolt pattern should match the C4.
Hope this helps,
Doc
Old Mar 9, 2005 | 06:51 PM
LxMan1's Avatar
LxMan1
I think that you will need a 92 or 92 4.6 to use the C4 bolt pattern.
